Screw clamp port lights
Growl
Oct 11, 2020
109
Hunter 28 2 Alamitos Bay Marina
My forward port lights (4) are leaking, I was thinking about opening them all and cleaning the black o rings and smearing some food grade silicon on them and gingerly adding tension then clamp! Any ideas? I’ll let you know if it does..
Feb 26, 2009
716
Oday 30 Anchor Yacht Club, Bristol PA
Replace the gasket! All seven of nine leak!
Feb 26, 2009
716
That's the Google way of autocorrecting incorrectly I didn't even notice that but I'm pretty lazy about editing my posts
Likes: Growl
Jan 24, 2017
669
Hunter 34 Toms River Nj
marine outlets are ridiculously overpriced for a neoprene or rubber port light gaskes. I removed one gasket and brought it to a local pool store a compared it to a few Hayward pool filter tank o-rings to match the diameter, after finding a comparable tank o-ring that matched the diameter I cut the tank o-ring to fit the port lights. If you do this make sure that where the ends of the o-ring meet glue the ends together with silicone or contact cement.
I did mine about eight years ago and used one pool filter o-ring and was able to do three port lights. I believe I paid about $20.00 for three o-rings and did nine port lights.
hope this pool tech trick helps
Growl
Oct 11, 2020
109
Thanks Captain but I have no pool supplies around so I will just have to go to west marine which is fine, do the O rings come cut to fit?
Jan 7, 2011
5,285
Oday 322 East Chicago, IN
You can certainly try to clean the gasket/o-ring and add some super lube or equivalent. I try to clean mine and wipe some lube on them annually.
Jan 7, 2011
5,285
That’s kinda what I was hoping I could do
Might delay the inevitable. I replaced the latches on my Beckson hatches with plain old screw knobs and really like them better…easier to dial in the right pressure to keep the ports from leaking.
Jan 24, 2017
669
if you know the manufacturer you can probably get the from here. And a think the gasket material is also sold by the foot from defender
Growl
Oct 11, 2020
109
Actually the rubber gaskets are in good shape, soaped rinsed and cleaned the 4 port lights and smeared a generous amount of food grade silicone on the gaskets and screwed them down. I like the idea of just replacing them with screw knobs. Tomorrow I’m swapping the decks so we’ll see if I have a good Seal.
Jan 7, 2011
5,285
I went from the original Beckson cams…
to these knobs from Amazon…
i much prefer the knobs,, but you do have to turn them more to get them to disengage from the port light.
Growl
Oct 11, 2020
109
Ordered on Amazon and awaiting!
Likes: Tally Ho
