It will be at home. Thank you very much for the well wishes.Are you keeping the boat at home, or in a boatyard? Usually a boatyard will have jackstands available to rent or buy. Good luck with your purchase!
Also, a great point. I will make sure to check the condition of the stands thoroughly. But, it's looking like it might be a good idea to invest in new ones to be able to have them on hand because I will need them throughout my life with my vessel. No?On the other hand... are you sure you would want to buy a jackstand that a boatyard would be willing to part with?
Try the makers site.Here is another place that is a better price
^^ Generally less expensive, but the chain position is less stable. Also look at Marine Mart (more like Brownell but less expensive).Have Hostar stands like them
As long as they are in decent condition. They are only there to keep the boat upright, all of the weight should be on the keel unless it is a swing keel
If you don't have chain for them, you can use shrink wrap string
