Hello -
I would like to ad an hour meter to my Yanmar 3HM35F. It seems that the two options for this are to either wire it to an oil pressure switch or to the ignition switch. I am planning on wiring to my ignition switch as my low oil pressure alarm goes off quickly if I kill the engine and leave the ignition on so I doubt I will be in a position to leave the key in/on and the engine off. My process is slightly complicated in that I would like to install the hour meter inside rather than in the cockpit. I don't really have a spot for it on my instrument panel and I have an old toggle switch that was abandoned at some point that I can pull out, enlarge the hole and should be able to slot the hour meter into.
I took a photo of the back of my instrument panel. I have located the blue wire marked with an M near where I want to place the hour meter. Can I splice into this wire? Or should I run an entirely new wire from the instrument panel all the way back? My concern is that with 3 wires already on the ignition post I am worried I will run out of room. Also, if I am being honest it seems a lot easier to spice into a wire rather than fish one through everything. There is a ground bus bar that I will be able to use nearby to complete the circuit.
