Gelcoat Cracks near skylights on Hunter 356
Jan 19, 2022
7
Hunter 356 Plattsbburg
Hello,
I am interested in a Hunter 356, 2002. The boat will be surveyed in march but I would like your opinion on thin Gelcoat Cracks on the deck, between the two skylights. Is it only Gelcoat and cosmetic or could it be a structural or humidity problem on the deck? These are the only cracks I have noticed on this boat.
Jan 7, 2011
6,001
Oday 322 East Chicago, IN
I think basically cosmetic. Unless you see that the windows are breaking out of their frames, or other signs of more structural issues. Gel coat cracks like those in the photo are common.
Feb 17, 2006
5,274
If you are really concerned and want to fill them, you can use Capt'n Tolley's Creepy Cure.
May 27, 2004
2,059
Just curious...
Are the sky lights near or over the cabin with the water leak?
dmax
Jul 29, 2018
1,349
Telstar 28 Buzzards Bay
You're going to want the surveyor to do a moisture check but most likely those are stress cracks in the gel-coat only and not a problem.
