When I first wrapped my furler, The line was a bit loose on the drum. When I wrapped the sail in a stiff wind, the sail wrapped tightly and ran out of furling line to get the sheets wrapped up on the sail.
So I fixed it. Now when I pull the furling line, there are plenty of sheet wraps to hole the sail in place. When furled, I tie off the furling line and the sheets in the cockpit.
Watching the video, being a solo sailor, it sure reduces my trips to the cockpit to raise a sail having my halyards at the mast. The presentation was not long, but the time could have been cut in half had he raised his jib with a halyard at the mast. Perhaps the time saved in raising sails, the reduction in friction (the hoist does not require a winch), and the near proximity to the sail so you can see if there is a hang up - correcting it before damage occurs is of value.
The adjustment of wraps is a great lesson. No reason for a sail to be improperly wrapped.
