Looking at my emergency tiller and just not figuring how I could possibly use it. The backstay prevents the tiller from moving side-to-side.
What am I missing?
What am I missing?
Hi Keith, I've never tried ours. It is, however, angled as referenced in sail sfbay's diagram. A picture of your handle might be of some help.Looking at my emergency tiller and just not figuring how I could possibly use it. The backstay prevents the tiller from moving side-to-side.
What am I missing?
Jim, I'm not so sure about that statement. In the mid 90's Hunter had "swept back" spreaders and I believe they were called B&R rigs but some, including a Passage 42 I was looking into, had a split backstay. For that matter, my 1994 40.5 has swept back spreaders like a B&R but it has a split backstay. In both the P42 and Legend 40.5 possibly they are not actually a full fledge B&R rig. The mast will stand without the backstay attached but I would not consider sailing it without the backstay in place. I'm not sure if it was a transitional thing but I'm pretty sure it was not a dealer or PO installed mod.Also there is no OEM backstay on Hunters with B&R rigging...
So I was curious about that comment.
Jim...
Our 1991 P42 has a straight backstay with swept back spreaders.Also there is no OEM backstay on Hunters with B&R rigging...
Jim...
You should try it the next time you're on the boat. An emergency situation is the last place you want to find that you have problems with it. If it works it's one last thing to worry about. On a C30 the wheel has to be removed. What I found was the nut was frozen and I had an awful time removing it. Could have been a serious situation if I waited for a situation to develop when I needed the tiller in a emergency.Hi Keith, I've never tried ours.
Agree, Don, a must do. Same with exercising a MOB rescue plan. Never done one, but have a mental plan on what to do. Big difference having a plan and finding out what does/does not work.You should try it the next time you're on the boat.
That is a good idea.exercising a MOB rescue plan. Never done one, but have a mental plan on what to do.
Hi John, my point is to not fall overboard under any circumstance. And if I do, swim like hell for the nearest shore. Some have suggested to leave a long knotted polyester line training the boat that in the event you do go over, grab the line and pull yourself aboard. Sounds easy enough, but very difficult to accomplish with our high freeboard. Tether in a good solution, but very inconvenient.One question. Knowing that you love to sail solo, pretty much doing all the sailing work on the boat, how is that mental plan going to be shared should their be a crew member left on board and your in the water? Unconscious.
Yep. There is a pole that extends out of the one you see. Maybe 2 feet. Would not want to use in bad weather for sure… of course the likelihood of needing it in good weather…………Doesn't look like a good setup. Looks like very little leverage if you're moving at hull speed under sail (or motor).
Then it's time to get creative. Lashing together a make shift rudder from boat parts as others have done. Do what you have to do to reach safe harbor. Hopefully, that never happens, but...Worse is the rudder gets damaged and the emergency tiller is useless. Then what do you do...
