I have the two tank WEMA gauge for fresh water and holding tank. The gauge body itself is marked UPWH and uses a DPDT selector switch to switch between tanks.
Recently both tanks stopped indicating. I suspected the gauge since I think it unlikely that two sensors failed at the same time. However the gauge checks out. I have good ground, good power to it, and doing the troubleshooting open circuit/shorting shows empty/full.
The only thing I question, while there is +12v going to the indicator, the indicator output to the senders is 5.4v. Is this correct, or should it be 12v?
