The plumbing below the galley sinks on our 41DS seems bizarre to me (see the attached photo). I'm thinking about flipping it end-for-end and the putting a short straight tail from the tee into the corrugated drain hose where the connection would be vertical. It would seem to me that this would promote better drainage while also making access to the valve manifold on the back wall somewhat easier.
I've confirmed that the nut for a standard 1-1/2" sink tailpiece will mate correctly with the threads on the tee. The only possible problem that I can see is that the existing pipe is 40mm O.D. which is about 0.075" larger than the O.D. of standard 1-1/2" drain pipe. If I can't get the corrugated hose to clamp to the 1-1/2" tailpiece I may have to improvise a bit.
I'm interested in thoughts on this, pro or con.
