Hello,
I am currently attempting to replace a thru hull on my Newport 30 it was damaged while removing the old plastic gate valve. This is my first attempt doing this type of job. All thru hull replacement videos I’ve seen online show the thru hull sticking out of the bottom of the boat. Mine however is glassed over so there is no exposed bronze under the water line.
i have sanded back the outer layers of my hull to expose the bronze of the Thru hull
and I’m unsure of the proper technique to complete this job. I was thinking of filling back in the layers I removed then installing the thru hull so that it sits on the outside of the hull, or should I fiberglass it into the hull how the original was installed?
Any advice would be greatly appreciated thanks
