I am getting my Hunter 270 pulled out for a little DIY session in the coming weeks. I need some suggestions, best practices or if you have an informative DIY method / video I would appreciate the help!
1. Replacing your rub rail. So the hunter 270 is a 2 system rub rail. I need to replace both. Does anyone have good info on DIY'ing this? I have both material on order from hunters website.
2. Wax / Polish top deck & sides. Recommend a specific material? What's best practice for this activity?
3. The rudder shaft where the bolts go through the plate and secure to the boat i see some 1/8" movement in the piece. I am resecuring it and refiberglassing the back to strengthen the rudder. Any suggesstions on this?
4. Anyone else have any recommendations on what I should work on while the boat is out?
General maintance stuff that is easiest done out of water?
