- Oct 22, 2014
- 24,938
On first look, at this point the motor steel shaft comes out of a "gear box" that as Greg indicates "wise to not open. I have not looked in side - yet. The steel shaft from the gear box drives a large toothed gear inside the wheel drive. The gear looks to be made of plastic. It drives the toothed belt. The belt teeth have a "rubberized" surface that wraps around the smooth surface of the Drive Wheel. The caution I stated in the description about "Do not get lube between the belt and the drive wheel" is critical to the operation of this design. I guess if you were redesigning this yo could put teeth about the drive wheel. While positive in making the drive wheel function, it would negate the ability to override the AP in an emergency. Because there is slippage you can force the helm to move even if the belt on the drive wheel is tensioned. Not sure if this was a design feature or a happy discovery.you'd also have to address the gear material on the motor.
When I had a jam on the clutch lever I was still able to control the boat to get into me slip (though it required some force to move the wheel). Not sure what would happen with a linear drive is there was a jam. Is the rudder just stuck?
Good design considers all of these events and tries to resolve them.
