My freezer would not cool after being shut down for several months, worked well before that. The compressor and fan runs as does the box circulation fan. No refrigerant escapes when the shreader valve is slightly depressed, so it seems it lost charge. I ordered a gauge set, vacumn pump and adapters. The fridge was once a cold plate but now is a flat white metal panel (don't know what it is called) with one 90 degree bend to cover two sides of the box, both are cooled by hermetic compressors with air cooling. Recharging the freezer seems straight forward with Calder's refrigeration book although Calder's book refers only to R12, but two things are odd. one there are no sight glasses on either system and although they are helpful they are not required for operation. The refrigeration box plate gets cold but the low pressure line does not get more than cool. I wanted to check its charge level but discovered that there is no low side port to connect to. The freezer has both high and low but the fridge has only the high, images attached. The fridge compressor was a replacement and it was charged so how do you charge it without a low pressure port or even check charge level? Is it accomplished through the high port? Anyone seen this before?
