I have the standard Volvo Penta Stern Gland seal on my Beneteau Oceanis 37, with a 25mm shaft and 43mm stern tube. The boat is a 2009 model, and the Yanmar 3YM30 engine has around 800 hours.
The original seal did not leak, but was getting rather old, so I replaced it two years ago. After replacing it we had a slight leak, but only when the engine was running.
Despite being extremely careful with the lip seals during the process the only thing I could think was I had damaged them during the process, so this year I replaced it again (being very careful with the lip seals, following the manual etc.). There was no evidence of wear (that I could see) on the prop shaft where the seal sits.
After the second replacement we still have a slight leak only when the engine in running...see the video...
We were careful with all the "standard" stuff: greasing, burping etc.
Has anyone had experiences with:
- Out of balance prop shaft, prop or coupling causing this sort of problem
- Wear on the prop shaft
- Excessive engine vibration
- Prop shaft not being centred in the stern tube
