Unbolt it from underneath, one big nut per stanchon. Some one most likely pushed on it with it looseView attachment 198613. How do I get off the cover? I did some light prying and decided to ask the group.
Also, if you look at the photo, the cover has a lip that is digging into the deck. This just looks wrong. Any explanation?
I can get at some of mine , if they are behind a cabinet ... you may have to remove cabinet to access. Other manufacturers are the same , my buddy has a Catalina 310 stantions bent from winter winds . Basically he has to rip apart all the cabinets to gain access.I got out my endoscope to look behind a wall (bulkhead?). There's about a 1/2 inch crack to allow insertion. I see the bolt, but how does one access it? It's on the port side behind the galley, but it appears that the easiest access is from the rear cabin. I'm surprised that there is no base plate as just bolted into the fiberglass with a washer doesn't seem very sound.
I was afraid of that. Maybe I can just pop a small hole in the galley cabinet if can locate the right spot with a nail or screw. Either that or cut through the bulkhead from the rear cabin. It's living up to my mantra that "nothing is easy".I can get at some mine , if they are behind a cabinet ... you may have to remove cabinet to access. Other manufacturers are the same , my buddy has a Catalina 310 stantions bent from winter winds . Basically he has to rip apart all the cabinets to gain access.
Using a flex shaft , universal joint with a socket may let you get at it
Always hate to see that kind of shoddy engineering where one has to tear stuff apart to get to a component or fitting. It's not a matter of IF, but WHEN, stanchions are going to require servicing. At some point in time they will need to be resealed, tightened, straightened, or possibly replaced. Builders should incorporated provisions for accessing without tearing the boat apart. I am not having problems with mine at this time; however, I dread having to deal with it when the time comes!I got out my endoscope to look behind a wall (bulkhead?). There's about a 1/2 inch crack to allow insertion. I see the bolt, but how does one access it? I'm surprised that there is no base plate as just bolted into the fiberglass with a washer doesn't seem very sound.
completely agree. I suspect the hull and interior engineers did coordinate. it gets worse as one moves forward as everything is sealed.Always hate to see that kind of shoddy engineering where one has to tear stuff apart to get to a component or fitting. It's not a matter of IF, but WHEN, stanchions are going to require servicing. At some point in time they will need to be resealed, tightened, straightened, or possibly replaced. Builders should incorporated provisions for accessing without tearing the boat apart. I am not having problems with mine at this time; however, I dread having to deal with it when the time comes!
Appreciate more photos of the stanchion base that you removed and damaged fiberglass.I was able to get the nuts off. I removed the medicine cabinet in the head and that provided me assess with a deep socket and extender. I was ready to drill a large enough hole through the galley cabinet but when I reached in, I realized that it was open. Lucky break. Tomorrow, I'll see about getting off the gunwale rail off so I can repair the fiberglass.
Great photos...much thanks! And, nice prep work too. Do you suspect any cracks beneath the toe rail? Is there enough space to glass a 1/4” SS backing plate from inside surface of deck? That would really stiffen the area. Also, what are you going to use to reseal the stanchion, butyl tape, 4200....? Sorry about all the questions!!I just noticed that the stanchion didn't have a gasket and only a small lip to prevent leakage.
Is that an end grain balsa cored deck or plywood? Strange design for the stanchion base, appears that most of the sealing surface is on top of the toe rail. Don’t think that the lip does much with regards to enhancing the seal.[/ATTACH]First layer of fiberglass.
