My factory installed holding tank has failed. The welded threaded fitting has cracked and the tank itself has a lot of calcium at the bottom so it’s time to replace the tank. However, the tank is really hard to remove because of the pour foam. Any recommendations on how to remove the tank? So far, I am using two machetes… it’s a shitty situation.
thanks
-wade
thanks
-wade
