I sail a 2011 B37. The feed for the stern tube water is on the back of the heat exchanger. The exterior of the nipple has blue corrosion (see photo ). I cleaned off and used WD40. It seems solid, so did not replace the part. I know the feed on other Beneteau boats are different. Stern tube nipple is good. Have any of you sailors had this issue? You always seem to have the answer!
