Anyone have experience with these alcohol stoves. I would like to get it working, I don't want to find a stove that will fit the hole in my galley. One side wouldn't deliver fuel, the other seemed to leak at the valve and keep flaring up.
Hahahaha - I see a true lover of these stoves has arrived to the conversation...I thought they were supposed to leak and flare up.![]()
Thanks, all I was seeing at Kenyon was electric and backyard stuff. Will be giving them a callCall Kenyon - Phone (860) 664-4906 . You can send the stove to Kenyon and they will fully refurbish it. Reasonable pricing also, IMHO. I sent one back to them that was quite long in the tooth (it was almost 40 years old) and it came back essentially brand new. I would definitely recommend that path.
dj
People are scared of the old style Coleman white gas stoves, which function in a similar way. (Tube needs heating.. Flareups if you dont use it right) I much prefer them over the current propane camping stoves.I still use my forty year old Kenyon. I have never had an explosion or fire like others report
Maybe that is the problem.. People like to wander off while the stove is running. Bad idea regardless of fuel.so they must be watched when in use
During my attempt I did notice that the open port window (which is a cheap plastic one pc molded plastic) was right above the flames and therefore in the heat. I've only had the '76 boat for over a month. One of the Winter project is to replace with metal/glass ports.I have fond memories of my mother lighting the alcohol stove on my Dad's cabin cruiser. Flames would shoot up because she let too much alcohol into the cup (Family lore is that she was a pyromaniac, who loved to make flaming desserts, while my Dad stood by with a fire extinguisher). Back to the stove, the flames would shoot up licking the cabin ceiling, or it seemed so, and uncomfortable close to the curtains. I also remember a number of cold dinners.
BTW, I think I posted years ago that I don't Rx using water to put out an alcohol fire as it can spread the flames around - if I remember correctly I was corrected. But I have seen it happen. I think a fire blanket at hand would be better (I have no formal fire training).
I love my little one burner white gas stove I have for camping. The wind screen and pans all fit into each other along with the stove for a very compact unit. Never had a problem with it.People are scared of the old style Coleman white gas stoves, which function in a similar way. (Tube needs heating.. Flareups if you dont use it right) I much prefer them over the current propane camping stoves.
If you know how to use them they work fine.
The same can be said for pressurised alcohol stoves.
That said, our Catalina 22 has a non pressurised alcohol origo and I love the simplicity.
I burned the paint of a range vent hood when making popcorn on my parent's electric stove. The popcorn overflowed and caught fire.i was in trouble.when they got home, but it taught me a lesson.
The one thing I did when I got the stove back from Kenyon was to set it on saw horses in my back yard and practice lighting and using it. I will confess, it took me a number of tries to really get the hang of it. Glad I did as once installed back in the boat it was quite simple and I felt very comfortable lighting and using it inside my boat. I'm sure that learning curve inside my boat would have been rather nervous making.Thanks, all I was seeing at Kenyon was electric and backyard stuff. Will be giving them a call
Here is a parts list schematic which will probably suffice...If you can post pictures of the stove. The linkages, and all that. I will probably remember at least something... I'll try anyway. It was quite some time ago...
dj
Might have to do it with trial and error ?can't get the control wheels lined up properly.
