We recently redid the wiring on our Dickerson 37 sailboat and ran 2awg from the batteries to the windlass. 2 AWG was chosen based on a 5% voltage drop. However appears the cable run is slightly longer than planned and possibly the terminations are adding to voltage drop. Appears the real voltage drop is closer to 10%. We have a battery selector switch so can choose either house or engine batteries. Initially the alternator was on the start batteries, and we normally run the windlass of the start batteries. No problem.
However, we now have the alternator on the House batteries and when running the windlass on the start batteries it appears to be straining more and the 125A MRBF blows at times, never the 100A breaker. I choose 125A MRBF as it was 25% larger than the 100A CB (Bluesea C-series).
No doubt I can safely go to 200A MRBF for the 2 AWG to prevent nusicance blows, but thinking I am better to up the windlass wire gauge. Running 4/0 I guess would be ideal, but that large cable will be problamatic to run through the boat. So I was thinking to just add an other pair (Red/yellow) 2awg wires from the battery posts (see diagram - we have battery posts in the anchor locker for the cable run to terminate at) to the circuit breaker and ground bus bar. Any thoughts, recommendations on this?
