Washdown pump location
Tim22
Jun 16, 2014
256
Hunter 310 Ottawa
I would like to install a washdown pump and am planning on t-ing off the head intake. Is It necessary to install the pump above the waterline? I have several possible locations below the waterline but no good options above.
Thanks
Tim
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Great question!!
You have a good plan to supply the washdown pump from an existing through-hull fitting, typically either the galley or head intake. A Y-connector lets the through-hull do double duty. Double clamp all hose connections below the waterline. Pumps push better than they pull, so mount the pump as near the through-hull as practical. A check valve installed in the hose connected to the other side of the Y-connector will prevent prime problems and eliminates the need for manual valves. A second check valve is required on the outlet side of the pump to prevent backflow, but most deckwash pumps are equipped with this valve.
You might find this article by Don Casey helpful: Installing a Deckwash Pump | BoatUS
and these: How to Install a Boat Washdown Pump | Boats.net Choosing and Installing a Washdown System | West Marine
Oct 24, 2010
2,405
Hunter 30 Everett, WA
Great question!!
Just curious why you would want a check valve for backflow prevention on a wash down pump?
Feb 21, 2013
4,638
Check valve stops backflow from the pump to mitigate loss of prime on the suction side unless you have a self-priming, positive displacement, e.g. diaphragm, pump.
279
J/ 32 NCYC, Western Lake Erie
Regarding the diagram, would it make more sense to have the check valve on the Intake side of the pump to keep the pump full?
Feb 21, 2013
4,638
Sailor Sue..........possibly, but a check valve in the suction it imposes pressure drop and can cavitate and damage the pump. The suction loop acts as check valve and mitigates backflow from the pump. The discharge check valve mitigate loss of system water column.
Tim22
Jun 16, 2014
256
Hunter 310 Ottawa
Any thoughts on whether the washdown pump needs to be above the waterline?
Tim
