I have a small woodstove in my fiberglass S/V. There is a small leak on the interior of the cabin, where the chimney exits the cabin. I want to remove the exterior chimney piece and re-seal it to the fiberglass, so see if this helps with the leak. I had planned to use 3M 5200 sealant for this job, though see in the info sheet for this product that they do not recommend using it in applications that can exceed 190 degrees (F). Does anyone have any thoughts on best sealant to use on a chimney hood being affixed to fiberglass?
Thanks!
Thanks!
