Keep fuel tank full?
Nov 16, 2020
11
C&C 37 San Diego, CA
I was reading the owners manual for my old Yanmar 3HMF and saw the recommendation to refill the fuel tank at the end of each day, with the intent to eliminate condensation on the inside of the tank.
Is this something that I should be concerned with? I usually think about refilling once I hit half full....maybe 6 months or so.
My boat is in San Diego....so fairly mild conditions both summer and winter.
Thanks
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Suggest topping it off when convenient to mitigate condensation and add diesel biocide fuel treatment to mitigate bacterial growth (bugs, algae, bacteria, yeast, molds and fungi) in diesel fuel and prevent their growth that can plug fuel lines and filters. You have 20 gallon fuel capacity. In my case, I top off my diesel tank (100 gallon capacity) every 3 months with typically about 5 gallons of fuel. That has worked well for all my boating life without any fuel issues.
More information on why you should keep your tank topped off: Preventing and removing diesel algae - BoatCoachBob
7,596
Alden 50 Sarasota, Florida
The consensus among the professional crew on some of the big boats around our marina, many of which have tank volume in excess of 1000gallons, is keep the fuel clean and fresh. None keep their tanks full unless they need the range.
Feb 21, 2013
4,638
Don.......good recommendation but unlike my diesel truck and skiboat turing over my boats diesel tanks, one with 100 gallons at 20 gallons per year and another with 530 gallons at 200 gallons per year, is impossible so I opt to keep the topped off.
NYSail
Jan 6, 2006
3,155
Beneteau 423 Mt. Sinai, NY
Sort of like the anchor question. I keep my tanks as empty as possible until I am going on a trip..... then I fill them. No fuel just sitting there. I have a great water separator if water gets in, but have never had a need to drain any from my racor. My personal experience only here in the ne for the past 25 years.
Location and tank material make a difference.
Good Luck!
Jan 7, 2014
454
Beneteau 45F5 51551 Port Jefferson
Topics never to be discussed: politics religion and condensation in fuel tanks. Some say it's impossible for the air in the average tank to contain enough water to do any harm.
higgs
Aug 24, 2005
3,715
Nassau 34 Olcott, NY
The only time I worry about filling my tank is when cruising or for winter storage. No issues with this boat for over 15 years not keeping it full during the season.
Likes: Tom Graves
Mar 26, 2011
3,841
Corsair F-24 MK I Deale, MD
The problem with this link is that he does not actually understand the math or the phenomenon. Some is correct, a few things he misses.
Example. One of the first things a large diesel tank inspector is trained to do, before entering a tank, is to check the roof for serious internal corrosion and unstable roof rafters. The cause is condensation, which is COMMON. I've seen a LOT of internal roof corrosion in tanks.
But yes, this is an interesting debate. Condensation vs. new fuel. The obvious answer is an absorbant vent filter, if you are going to worry about it. They do work.
Mar 26, 2011
3,841
Size matters.
Jim...
Perhaps that was a joke.
No, in this math it does not, really. I have also inspected a few marine tanks, same problem. I've see condensation inside downward sloping fuel hoses. That fact that it is in the bilge of a boat does help. The fact that boats are within a foot of the water all the time (high humidity) makes it worse.
One obvious thing that is missing in the math is that once a drop of condensation falls, it is trapped under the diesel and cannot escape. It's a one-way trip. Another thing he misses is that the steel tank roof and upper walls can be considerably cooler than the air and are not buffered by the temperature of the fuel.
Jul 7, 2004
8,498
Hunter 30T Cheney, KS
I never fill up my tank all the way. Besides adding stabilizer and Biocide, I added an H2Out fuel vent desiccant dryer. I can see that it works. Over time the (reusable) crystals turn pink.
Somethings you can control and some things just are.
Water in diesel is only something I can possibly influence, cope with, and attempt to treat.
I have a good filter. I only fill the tanks (2, 85 gallons each) if I am going on a long trip. I flush some fresh fuel into the tanks along with biocides as identified in Practical Sailor magazine. I carry replacement filters.
The challenge is your fuel source can be everything from wonderful pristine to disastrous. Look for fuel in places that pump a lot of fuel too get the freshest and hopefully with the least amount of dissolved water.
Change your O rings on your intake pipes regularly.
When heading out on the water into a lot of wave chop, expect any crud in your tanks to be stirred up and sucked into the fuel lines.
Be ready to shut down if your engine suddenly races into high RPM. You could be experiencing fuel starvation. A quick shut down can save you from having to prime your engine's now emptying fuel lines.
Likes: Sailfanatic
Dec 28, 2015
1,923
Keeping your tank full to decrease the potential of water condensation is the most correct tactic but life and logistics doesn’t make this a hard fast rule. If the tank is poly then the need is even less
Oct 26, 2008
6,370
Catalina 320 Barnegat, NJ
Short answer ... I don't know anybody who tops off their tank at the end of each day sailing. Most people fill up only when they need to. MIld, stable temperatures, mostly dry humidity ... I can't think of any reason why you should be concerned about condensation in your fuel tank. Do you have a clear bowl with your primary fuel filter? Have you ever seen water in the bowl?
