Consider going to an LED bulb. Our old tungsten bulb was about 1.2 A while the LED is 0.10 A. Saves about 11 AH over a 10 hour night.Anyone know the number for the replacement bulbs.
IF you know the bulb type, you can cross-reference and purchase it here.Okay, do you have a nomenclature or model or product number for those light bulbs in the LED.
Until that lightning strike...no more climbing the mast to change bulbs.
Doug, I am about to change out my B323 steaming bulb. Any tips for me? I wonder if there is a height requirement for sailboat steaming lights?You are really going to have to know the manufacturer of the fixtures in order to determine the bulb type.
One person mentioned AquaSignal, mine are Perko, others are Hella, etc.
When I bought my 323, it came with a spare parts box from the factory. It had spare light bulbs in it, but many were not for the fixtures on my boat. This was because my boat was shipped to the dealer with a furler mast, and I negotiated a mast change to a conventional rig.
(The fun part was when the steaming light burned out, I climbed the mast to change the bulb, found out the Perko fixture was riveted to the mast, and access to the bulb was from the back!)
AH- the rivet trick is the type I was wondering about.Doug, I am about to change out my B323 steaming bulb. Any tips for me? I wonder if there is a height requirement for sailboat steaming lights?![]()
I bought the boat in 2012 From the original owner who had put almost 50 hours on the engine. I’m sure the bulbs are original. Most likely though, someone will go up the mast.Dave.
Did you buy the boat new this year? If not then the answer is No. There is no way to be certain what is on your boat. Lights are a consumable item. You could have a AquaSignal or a Perko. Depends on what a Previous Owner installed when they were faced with the same problem.
you could try to take a long shot picture and blow I the image. .Or send a kid up to tell you what the bulb looks like or even retrieve it so you can match the bulb.
It is a crap shoot.
