Replacing frameless acrylic fixed ports
Apr 5, 2009
3,333
I finally got around to replacing the lenses in the fixed portlights in my 88 C30. In the originals, the lens was held in place with screws around the perimeter but I used VHB tape and Dow 795. Here are some photos. The three vertical strips of white tape form a hinge to allow the lens to be properly aligned and then rotated up out of the way to strip the paper off the back and wipe down with alcohol before sticking to the tape.
I removed the old lenses with a kitchen pairing knife that was thin and flexible enough to fit into the small gap and cut the old silicone.
I then used the original lens as a template to cut new 1/4" "dark smoke" cast plexiglass to shape. After drawing the shape on the sheet of plexiglass, I cut the rough shape on my bandsaw and then stuck the new to the old with SailRite basting tape.
I used a flush cutting router bit to trim the rough blanks to the same size as the originals. After switching to a 45º bevel bit with bottom bearing I cut the 45º bevel into the back side.
The original lenses were tight fitting with almost no gap around the edges and very thin layer of silicone between them and the cabin. If the sealant is too thin, it can cause leaks from thermal stresses so i needed to make the new lens about 1/8" smaller on each edge. This also gave me a big enough gap to gun the silicone into. I did this by adjusting the depth of the 45º bevel deeper to cut the extra 1/8".
After cutting all of the old silicone off with a sharp chisel and cleaning it with sealant remover and sanding, we applied VHB tap to the edge of the opening and masking tape to the perimeter. (In hind sight, it would have been better to mask the cabin top after the new lens was stuck to the VHB.) Then we positioned the new lens in the opening and when happy with the location, added three tape "hinges" to the top to hold it in position.
The lens was flipped up on the "hinges", paper removed from back and cleaned with alcohol. Then the backing on the VBH was removed and the lens rotated back into place on its hinges. The alignment was perfect.
The project was then finished with black Dow 795.
So nice to have clear window for the first time in 20 years.
291
What a nice looking job! Looks very good and thanks for sharing - something I'd like to tackle on our boat.
3 questions:
  • Where did you purchase the plexi?
  • Was there any chipout when using the router on the plexi?
  • It appears that your forward portlight curves inward slightly with the contour of the cabin top. Was the VHB tape strong enough to 'pull' the lens against the opening or did you have to setup some type of brace to secure the lens against the fiberglass to allow the project to setup prior to caulking?
dmax
Jul 29, 2018
1,362
Telstar 28 Buzzards Bay
Very nice - thanks for the write-up of your experience, will be doing this myself down the road.
Apr 5, 2009
3,333
3 questions:
  • Tap Plastics It cost $236.33 plus shipping for a piece of dark smoke 1/4" x 26" x 32" That I cut the four fixed ports from. (2 each side)
  • I used new bits with ball bearing guides and all cuts were perfect and smooth.
  • There is a curve to the full length of the cabin and toward the cockpit it is a warped curve (twisted) I had 1x2's all cut to brace between the lifelines and the lens but did not need them. On the first one, I stuck down a couple of inches on one edge and wanted to move it just a tiny bit but was unable to get it free, seconds after it touched. When they say VHB (Very High Bond) they are not kidding. I used 3M 5952 VHB. The 3rd photo is right after I pressed the rear lens into the tape and you can see the curve and twist. That is held in place with nothing but the VHB. It is a pressure sensitive / aging adhesive which means the bond gets stronger with pressure and with time. I put it into place and then pressed it hard against the cabin with the heel of my hand all the way around the perimeter.
19thol
May 2, 2014
111
Hunter 30 St.Petersburg, Fl
Really looks nice, that's one of the jobs I've been gonna do for years, hard to get motivated since the old cracked ports don't leak, they just look like crap. Already bought the tape, now for the hard part!
Nov 25, 2013
51
O'Day 26 325 Lake Erie, Sandusky, OH
Thanks for sharing your experience with the new windows! And thanks for putting the link on my post about putting in ports on my O'Day 26. I plan to actually install this spring so - your post is timely
Castrilper
Apr 5, 2009
3,333
Nice job Hayden! It will be interesting over time to see how well the tape works.
I look at the tape primarily as an installation tool that holds the lens in place in the proper alignment with a gap between the lens and the fiberglass to allow for the installation of the Dow 895 which is the primary defense against leaks. The tape is waterproof and theoretically should prevent leaks on its own so that makes it belts and braces.
Jul 26, 2009
291
Every time I see this post it motivates me to put it higher on our to-do list!
In researching the project in the past, I noticed that some folks paint the inside borders of the plexi to hide the VHB tape from showing through when viewed from the outside. I have to wonder how much the paint would compromise the bond between the VHB and plexi. Did you paint the inside borders on your lenses prior to installation and if not, is the VHB visible from the exterior in sunlight or does the tint hide it's presence?
Thanks, and again - what a nice job.
Likes: Ward H
Apr 5, 2009
3,333
No, I did not need paint because I used a black VHB tap to avoid that very problem. The downside to using black tape is that the thickness of the tape I could find was only about 60% of the thickest gray tapes which makes gunning the 795 into place a bit harder but with care and good technique, I was able to get the Dow to the edge of the tape and no white showing through.
Likes: Castrilper55
xavpil
Sep 6, 2022
376
Jeanneau Sun Odyssey 419 Milwaukee
Awesome post!!!!!!
The plexiglass is color tinted so the pigment is IN the whole plexiglass. However from your pictures it looks like you see clearly from inside the boat to out, and you can't see from outside to inside...
Did you treat the window afterwards so they act like a tinted car window?
Apr 5, 2009
3,333
Awesome post!!!!!!
That is standard "dark smoke" acrylic. You can see through it without problem from the side that has the least light. So, during the daytime, you cannot see into the boat but can easily see out. On the other hand, at night, anyone on the dock can see everything that is happening inside the boat if the lights are on inside and those on the inside will never know they are there. It makes curtains an important thing.
xavpil
Sep 6, 2022
376
Well I learned something new. Thx Hayden!
Likes: Hayden Watson
