Hey Hunter lovers good evening,
The engine blower on my hunter 49 is defective, I just bought the boat a month ago so going through it to find the good, bad and ugly.
After investigating the blower 2 of the connections at the blower on the relay were broken/corroded, I replaced the relay but still nothing, I know blower works I connected it to power fires right up.
Before I head down the rabbit hole.
Questions..
1-Does the key in ignition need to be on to start blower?
2-Blower switch up or down to turn on?
3-Anyone know correct wires to pins on relay so I know it’s wired right(wiring schematic?
4-I checked power at blower switch butbb can power goes in and out regardless of switch position?
Any advice helps
Scotty
Questions..
Any advice helps
Scotty
