Hi
I have a 460 in the UK which has a leak I am trying (frustratingly) to trace.The boat is out of the water by the way.
I think it is coming in via the mast step and then travelling down inside the compression post exiting at the bottom. I found water there today (see photo) and about a gallon in the bilge - which I had dried out last week. We have had a lot of rain.
I believe the mast compression post is hollow and can see from underneath where it pokes through a hole in the deck presumably to sit under the mast deck plate. I believe the deck plate is solid apart from the bolt holes which are dry on the inside.
I can find no water in the area under the deck hence why I think it must be travelling under the deck plate and then down inside the post. My confusion is how so much water is coming in as I am struggling to find any significant gap at deck level and am a bit loath to take the mast off just to have a look.
Any suggestions gratefully received
Regards
Jim
Regards
Jim
