I have a 1986 H34 and most of the running rigging was replaced by PO. The reefing lines come out the end of the boom ( see pics below). The other ends are made fast on a winch mounted on the mast. There is a hook for the luff reefing cringle. There are two padeyes aft on the starboard side of the boom and a block aft on the port side. I've done a lot of research and can't quite find the answers I need.
How can I tell if the lines run straight through the boom or have blocks inside the boom? I want to replace them.
I've seen numerous reefing rigging pics. For the leech, should I run the lines up the port side, through the cringles and down the starboard side to the padeyes?
Thanks much,
John
Thanks much,
John
