Just purchased hull 355 / Doing a full recondition over the next few months.
Mast Slug: I am presuming the mast slug with threaded extension is to hold the top top while up. Mine seems to be bent out of shape. Is this supposed to be straight. Is the pop top just held against the mast with a wing nut?
Mystery hole at top of Keel trunk. What is this hole for. Goes through to the other side. Maybe a stop pin?
Open cubby by starboard lazaret. This seems like it would just hold water. No drain. What is it's intended purpose?
The inspection port seems to have been added to gain access to the lower rudder dungeon bolts. A tunnel right through the foam.
