Webasto Thermostat Contoller acting up
Feb 16, 2021
544
Hunter Legend 35.5 Bellingham
As we’re getting our boat up to speed, we’ve been encountering some fickleness in our Webasto thermostat controller 1320415A. When I turn it on, I have to fiddle with the cover in order to get it to stay on. I took the cover off and checked the connections, and the issue seems to be with the on/off switch itself. When I futz with the switch, the indicator light will go on and off. Short of replacing this unit entirely (ebay has it for $150, buyer always beware), has anyone dealt with a similar issue? What was the fix, if any?
8,062
If you can get to the soldered connections on the rocker switch, you may be able to de-solder it from the unit.
The switch should have its electrical values printed on it.
