Painting over molded non-skid deck
Sep 28, 2020
14
Cal 21 Cow Island NH
I am refurbishing a Cal-21 that has molded non-skid decking in diamond pattern. I’d like to paint over it with Total Boat Total Tread non-skid paint. Can I do that? And if so what prep-work should I do? I heard some people have sanded the molded non skid right down. Thanks
Jan 25, 2007
371
Cal Cal 33-2 cape cod
No need to sand out nonskid diamond pattern. I cleaned nonskid, wiped surface with acetone, then laid 2 coats of Total boat nonskid. Here is result. The diamond pattern won't be as pronounced when painted, however, will have more nonskid properties inherent to the paint. Good luck.
14
Thanks so much looks great. That’s what I was hoping for!
Jan 25, 2007
371
Easy job..although a bit time consuming. I mixed Total Boat nonskid 2 parts white, 1 part sand/beige. Post painting, Woody Wax worked great to prevent nonskid getting dirt ground in, actually good product for any nonskid. Have fun.
Likes: PeteTheri
Sep 28, 2020
14
I was considering just using the white but I see plenty of people use the off white or beige and I’m just afraid I won’t like the 2-tone effect on the deck
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Total Boat Total Tread non-skid paint preparation from the manufacturer:
1. Remove all surface contaminants including water, dust, wax, grease, and surface blush.
2. Wipe the surface with a clean, lint-free rag wetted with TotalBoat Dewaxer & Surface Prep.
3. Abrade the surface lightly with a Scotch-Brite™ pad, and wipe the surface clean with TotalBoat Special Brushing Thinner 100.
https://doc.jamestowndistributors.c...lBoat/TotalBoat _TotalTread_TDS_9.25.2018.pdf
Likes: PeteTheri
Feb 21, 2013
4,638
just applied 2 coats of Awlgip color-matched polyester urethane topcoat paint with converter and reducer Awlgrip Polyester Urethane Topcoat |Awlgrip Topside Paint (bottompaintstore.com) to 600 sqft of patterned non-skid. For your sailboat might consider adding a flattener to reduce it gloss for potentially improved traction, albeit reduces it durability according to Awlgrip's U.S. technical specialist. Makes the 37-year od boat non-skid look close to new and not slippery, leaves no scuff marks and cleans easily.
112
Dufour Dufour 34 Clipper Yacht Harbor
So 3 years later, is it holding up nicely ?
Jan 25, 2007
371
Yes, however, I have touched up paint every year. (1-2hrs each year) This has been easier than cleaning old non-skid, and less time. The overall look, I believe is very good, not perfect, not new, yet little to no maintenance and matches the rest of the boat.
Likes: zinahewitt
