filling a void
Jun 3, 2004
42
Catalina 34MKII 1717 Merritt Island, FL
Hello, What would be the best way to fill a void between the deck and the headliner. My port traveler bolt needs to be tightened but I cannot because the plastic headliner will just crack if I tighten the bolt much. Thank you
Jul 7, 2004
8,536
Hunter 30T Cheney, KS
If there is a void, that's not a real good place for tightening down a bolt. Filling with epoxy might resist compression but I'm not sure.
Could you drill a an oversize hole and put a spacer in there flush to the headliner, then a washer before the nut?
Likes: ggrizzard
:plus:
Or get a small hole cutting bit like this style
Then cut through the headliner only and insert a backing plate (or large washer) and then cover the hole with a bung cap. You can get bung caps in the "hard to find parts" drawer in the hardware section of Lowes. The drawers look like this...
and the caps look like this...
After you finish installing the traveler, cover the holes with the bung cap. You can also find these types of caps on Amazon. Do a google image search for "hole caps". West Marine even sells some intended to run a wire behind the headliner and give a port for the wire to exit.
There are a lot of choices. You just need to find one that is close in color and has the right hole size.
capta
Jun 4, 2009
5,078
I think rgranger has it right. nuff said.
