I have an 1980 oday 30 and this is my problem I have a 40 year old Oday I bought just a few years ago and last season when I put it on the hard I looked at the very bottom of the inside of my hull and found this. I am sure the previous owner did not completely drain the hull and it froze and thawed creating this hole in the bottom. I cleaned up best I can for now and the water keep seeping into the hole from between the layers I think. My plan was to dry it and use epoxy resin to fill it and strengthen the hull. I am not sure how to dry it and if this is the right approach . I sure could use some good good advise because once its in the water again it will never dry out. What is the answer?? and is this an encaplelated keel or bolted does anyone have any information on this. And is this a structural problem or more of a cosmetic one thank you for any info
