I used the "Adjust" setting, and the needle wouldn't go up from 0. I played around with it for hours.What did you set for the programing?
Yes sir, double and triple checked that they are all connected correctly. It matches the diagram in (1) above. Also, the tachometer turns on, travels through the whole range when it's "booting up", and the engine hours read 0.0 on the LCD display. It just won't take whatever signal is coming from the alternator. The only variable left to isolate is whether the AC tap tach signal (the signal going to the tach) is malfunctioning, but I don't have a comparison to what it should be and I couldn't find online what it should be for this engine/alternator.Have you checked the wiring of the Tach?
Power and AC Tap cable to the correct pin on the tack?
Proper Ground Pin connected|?
It's wired into the same ground as the other gauges. That should be adequate, right? And pardon my ignorance, but how do I confirm that it is grounded?Also make sure your ground is still grounded while the engine is running. It probably is but I would check it.
I tried setting the pulse to 12, and that didn't change it. I also did the calculation that they suggest, which isI found a video online, you might look on YouTube. I suggest setting pulse to 12 and then go from there.
With a meter or a test light.It's wired into the same ground as the other gauges. That should be adequate, right? And pardon my ignorance, but how do I confirm that it is grounded?
Pardon my ignorance/inexperience, but what does regulated voltage mean in this case? The alternator puts out around 14V, and the voltage I get from the AC tap with the multimeter on AC mode is a steady 4V regardless of throttle.Earlier Maine Sail posted you should have 1/2 of the regulated voltage at the AC Tap. Have you rechecked that? (I didn't see where you did).
Most of the settings you have been trying are to set the correct RPM. I would think if the tach was getting a signal it would show something even if it was wrong.
I checked your link you posted of what you bought and see two downloads. One is the tech data sheet and the other is the manual.
On the tech data sheet (it says with and without hour meter) it doesn't have a wiring diagram but it does have pin assignment.
That shows Pin 4 for the signal input.
On the manual download, the one @jssailem posted, it shows the AC Tap connected to Pin 8.
Might be time to call the number on page 1 of the manual and double check the pin assignments.
The first thing that I noticed on the photo of your alternator is that you have the original alternator bracket with the support on the front gear cover. That system has been known to cause breakage of the aluminum front gear case and these things are now made from "Unobtainium". More than one M25 series engine has gone to the scrap heap because of that bracket.A picture of the alternator:
The engine in the photo is M2-12, not M25 though?The first thing that I noticed on the photo of your alternator is that you have the original alternator bracket with the support on the front gear cover. That system has been known to cause breakage of the aluminum front gear case and these things are now made from "Unobtainium". More than one M25 series engine has gone to the scrap heap because of that bracket.
Westerbeke make a retrofit bracket that solves the problem. It is not cheap but much cheaper than a re-power.
Did you ever resolve this? How?The engine in the photo is M2-12, not M25 though?
Does the same alternator bracket problem apply?
I can't find any specific information.
The bracket looks the same as the one "recalled" by Westerbeke but the Catalina Direct link you posted doesn't list M2-12 as one of the engines that this kit would apply to.
Thanks!
BTW, if anybody is still wondering about the tach issue, I purchased this boat from Tylcole back in May and the problem is still ongoing.
I ordered a new alternator, will rewire and report back, if anybody is interested.
PS sorry for resurrecting an old thread.
I presume you’re asking because your tach stopped reading RPM’s? If the one for your Beneteau is a Yanmar it probably doesn’t have the same cause as the OP’s Universal. The Yanmar YM tach is driven by a signal wire off the side of the alternator. It’s probably a yellow wire going into an orange wire. It should give a square wave with voltage 0-15V and frequency dependent on RPMs. Check the connections for those wires along the way and maybe it’ll be an easy fix of just cleaning up a bad wire connector.Did you ever resolve this? How?
I'm not sorry for resurrecting this old thread.
My tach works fine. The LCD display needs replaced but that's a completely different matter.I presume you’re asking because your tach stopped reading RPM’s? If the one for your Beneteau is a Yanmar it probably doesn’t have the same cause as the OP’s Universal. The Yanmar YM tach is driven by a signal wire off the side of the alternator. It’s probably a yellow wire going into an orange wire. It should give a square wave with voltage 0-15V and frequency dependent on RPMs. Check the connections for those wires along the way and maybe it’ll be an easy fix of just cleaning up a bad wire connector.
if your tack is a "hall effect" or "magnetic sensor" type, it will not use the AC tap on the alternator. I believe it will need a sensor on flywheelOh sorry, this one:
Heavy Duty Tachometers, Hall Effect and Magnetic Sensors | PARTDEAL.com
Buy tachometers for heavy duty applications for less at PARTDEAL.com. Wholesale prices.www.partdeal.com
