I have a 2000 Hunter 240 that has developed a leak at the stern. There was just a trickle of water coming through pin holes in the glassed-over interior deck to hull joint while sailing last summer. I could see minor cracking in the new hull paint at that joint, but no obvious intrusion point. I tipped the trailer back on some blocks and filled the back of the bilge with water from a hose. There were a couple small seeps at first, then the whole joint seemed to go with water seeping along most of it after a minute or two. Not surprised it failed, but surprised it held up as long as it has.
I removed the hull paint and it appears to have a marine bondo type filler between the two hull pieces, with an approximate 1.25" gap at the lip. A lot of voids in the filler material as I started pulling out chipped pieces. Several cracks in the filler were also darker indicating water passing through them.
Now my question has to do with repairing the joint. I will clean the filler out of the old joint, then thinking I can probably inject 5200 along the actual seam up inside the joint cavity (I don't want to force it apart if I don't have to as it will further damage the fiberglass over the joint on the inside). That will get me water tight. Then I'm not sure what material I'd use to fill the rest of the 1"x1.25" cavity. I think I need something that stays somewhat flexible?
Last year I split the hull joint under the rub rail on the port side minimally from stern to chainplates and filled the joint with 3M 5200 to fix another leak.
Thoughts, ideas, suggestions, and admonitions are all appreciated.
