H310 - Where does anchor locker drain?
Jul 2, 2019
102
Hunter 310 Pine Beach, NJ
My boat is tarped from the stern to just behind the anchor locker in dry dock. Still getting a bunch of water in the bilge and having removed batteries I have to pump manually. Took it a couple gallons in a month so I'm sure it comes from the anchor locker. There's some crud in the bottom right now so I will go back today with some tools and a vacuum to get to the bottom. there is a drain port but it's a good foot up the side. Did they intend for this to just drain straight into the bilge?
Tim22
Jun 16, 2014
257
Hunter 310 Ottawa
My H310 has two drains in the anchor locker - one is low down and one about a foot up. They are on opposite sides.
When I first got the boat about five years ago, I had a lot of water coming in through the anchor locker every time it rained. The water was running over the stern lip of the locker and back through a gap where the caulking had broken down. I had to get my head right into the locker to find the problem. When I removed the fibreglass ceiling panel in the front of the v-birth I found the dividing panel between the anchor locker and v birth was soaking wet. To fix this I glassed over the gap from the anchor locker side and this solved the problem.
Tim
Oct 26, 2010
2,234
Hunter 40.5 Beaufort, SC
I do not know about the 310 specifically, but on my 40.5 there are two drains. One low in the locker about 2 inches above the bottom and a second one about 2 feet up on the opposite side. If you have access to look under the anchor locker under the for leakage from area. Water that leaks there will eventually find its way to the bilge.
Both of these holes are connected from the anchor locker through a short PVC pipe (about 2 inches long) to the outside of the hull with a small clamshell on the outside of the hull where the drain exits. There was no collar on the inside to allow a good seal and on my boat the seal failed. I removed the clam shell, drove out the pvc piece. Then I fashioned my replacement pvc with a small collar to allow me to get a more positive seal with 4200 on the inside and sealed the outside around the pvc pipe where it exits the hull with 4200.
Search for the following thread and look at post 14 for the fix.
hunter-40-5 anchor locker drain leak fix
Jul 2, 2019
102
Aha. I cleaned out 6” dirt in the locker and revealed the lower drain. Mine also has a bottom drain and another, about 2’ up. Didnt realize about a tubing but it makes sense as the locker is molded in the upper so it needs a connect to the hull section. Will remove clamshell and see where that takes me.
Jul 2, 2019
102
Turns out there is no pipe connector on the lower drain. locker is sealed directly to the outer hull. There was a small crack but after rinsing the locker a larger crack appeared in the bottom. I taped a rag around a pole and used brake cleaner to clean the entire bottom surface. Then taped a 1" paint brush to the pole, after snipping the bristles to make them stiffer. I used this to brush 3M 5200 liberally on the whole area. I dare it to leak now haha. Thanks for the help guys.
Oct 26, 2010
2,234
When you have the clamshell off make sure the anchor locker is actually "bonded" or sealed against the hull. You should be able to reach your finger up into the hole from the hull side and feel if it is actually bonded rahter than just "butted up" between the hull and the locker. From a design standpoint I would not think they would want to bond the inner hull liner directly to the hull at this spot since flexing might weaken or break the bond. Just a guess though, your milage may very.
Likes: wdonovan
Jul 2, 2019
102
Yup. Done it.
