Rule Auto bilge pump not so auto. Is it toast?
Jan 3, 2020
53
Hunter 27 Hoboken
Hi all--
Wanted to find out if this is a common problem:
Manual circuit works, auto test switch and that circuit does not.
Is this a replacement issue or should I get a float switch for the manual side?
thanks!
Mar 6, 2008
1,369
Check the voltage on the auto side wire.
Mar 6, 2008
1,369
If voltage is available to auto wire, then turn it upside-down and see if the motor runs. If yes then you can install an external float switch to the manual wire and save the pump.
Likes: SV_IdleHour
Tom J
Sep 30, 2008
2,325
Catalina 310 Quincy, MA
You can install a float switch to the manual side, but then you lose the manual function. Since mercury switches have been banned, the reliability of any bilge pump switch is suspect. I prefer to use an external float switch type of pump, since it is easier and cheaper to replace the switch, rather than the whole pump.
Likes: SV_IdleHour
Tom J
Sep 30, 2008
2,325
You can use the manual wire with a float switch and still have manual control. Just connect the manual hot wire to the pump side of the float switch.
Ken
Not if he is using his old pump with the internal switch. What you described is the normal hookup for a pump with an external switch.
Likes: SV_IdleHour
Tom J
Sep 30, 2008
2,325
Perhaps I misunderstood your question. I thought you intended to use the manual switch circuit to power the float switch. If, however, you intend to rewire the float switch with both the automatic and manual circuits, and feed the manual side of the pump, then, indeed you would have normal functions and wire the float switch as Ken described.
Likes: SV_IdleHour
Jan 3, 2020
53
Hunter 27 Hoboken
Jan 3, 2020
53
Hunter 27 Hoboken
ordered a float switch and a 3 way panel switch, I'd like to have manual control but was worried the pump is compromised. gonna give it a whirl, and thanks!
Mar 6, 2008
1,369
To clarify, the pump in the photo has 3 wires. One is from the switch on the panel labled Auto. At the pump connect the Auto wire from the switch to the new float switch wire and the other side of float switch connect to manual wire. This setup will make the pump work as before in manual and Auto mode.
I am assuming that the Auto wire at the pump side has voltage when panel switch is in Auto position.
Haro.
Likes: SV_IdleHour
May 24, 2004
7,179
CC 30 South Florida
If I recall correctly the h27 has a real shallow bilge that precludes the use of a float switch. The boats were originally fitted with a manual switch only. I would go ahead and replace that pump with an electronic one Rule S-Series that turns on every 2 1/2 minutes for 1 second to sense for water and if it does will continue to run until no more resistance on the impeller is felt. The power use is nil It does not require a float switch and will get a larger amount of water out than a float switch will allow. A 500GPH is enough for that bilge.
Likes: SV_IdleHour
Jan 3, 2020
53
Hunter 27 Hoboken
thanks Benny. definitely shallow.
