replacement pads on my jackstands question
CYQK
Sep 11, 2009
605
beneteau first 42 kenora
time to replace the plywood on my jackstand pads
thinking about putting astro turf on the top
good idea or bad idea??
should i just leave it bare plywood??
thks
gary
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
Use exterior grade plywood cut to size and seal the edges. Optionally, use carpet on top.
Likes: Parsons
Jul 7, 2004
8,536
Hunter 30T Cheney, KS
I don't see anything wrong with using AstroTurf. I'm a proponent of cushioning the pads. I bought an outdoor carpet remnant and stapled it on the pads. It's even color coordinated with my boat trim :thumbup:
Likes: Parsons
Jul 12, 2011
1,165
Leopard 40 Jupiter, Florida
Great suggestions here, particularly about protecting wood exposed to elements. I like thin carpet scraps over the plywood. Whatever you do, make sure that the bolts do not come near to your boat, considering the wood will compress and bend a little over time.
CYQK
Sep 11, 2009
605
Yea
Going to seal the plywood first,countersink the carriage bolt heads and glue the outdoor turf over top
Thks for the replies
Dec 14, 2003
1,450
I have had very good success with rubber step covers bought at the big box and cut to size. Protects the hull and lets water drip out. The 6 pads only needed for me to buy 2 of the rubber steps. Good luck
Likes: SailingLoto
DArcy
Feb 11, 2017
1,786
Islander Freeport 36 Ottawa
I have always used carpet remnant over the pad. I've never thought of astro turf but that may be a better choice. Let us know how it works if you try it.
Jan 24, 2017
672
Hunter 34 Toms River Nj
seal plywood with good patio deck sealer then place a foam garden pad between the hull and pad.
Apr 26, 2015
663
S2 26 Mid On Trailer
This looks interesting, however I would only need 8 square feet, which at $2 a square foot is pretty reasonable. Unfortunately, I'd have to buy 24 square feet. :(
I had left overs but they come in handy here and there. A piece in front of my workbench to stand on is nice. They make 1/2" which is lower priced.
