Yanmar 3GM30F - Injection Pump sensitivity -Help?
Oct 26, 2008
6,432
Catalina 320 Barnegat, NJ
As I've said before, I'm taking my gear case off to replace the gasket and hopefully repair an irritating oil leak. To do this I have to take the fuel lines off so that I can lift the injection pump body clear from the gear case. I definitely don't want to do too much because the timing appears t be very sensitive and I don't want to open a can of worms!
I started to loosen the nut that connects the high pressure fuel lines on the first delivery valve. I found that I needed to hold a wrench on the delivery valve spring holder to keep the assembly from turning, which was bending/crimping the line. So I got the first one off and realized that I would need to remove the spring holder to get a wrench on the 2nd holder. After I got the 2nd line off, I found that I could get the 3rd line without removing the 2nd holder.
So that part is good but I got a little curious about the components. I lifted out the delivery valve, the packing, and the valve holder.
I see there are some tests I can perform to verify if the delivery valve is functioning well. You can see there is a lot of debris to be cleaned off the engine. I was able to lift that particle out with a tweezers that you can see in the photo below. But I'm worried about infecting the system with dirt by opening each of these valves. Other than the one that I pulled apart, I don't have to open the other 2. Is it worth opening and checking the condition of the valve, the delivery spring and the valve holder, or is something I shouldn't touch if not necessary.
I'm most concerned about messing up the timing. The instructions say that the timing adjustment shim under the pump body is critical and a lot of care has to be made not to mess it up. Also, the parts can't be miss-placed from one injection to the other and the plunger shims in particular should not be changed. To mess it up means having the pump adjusted offsite with a injection pump tester. I don't want to go there ... I know that the delivery valve and the holder have to be paired so I would be careful not to mix any pairs.
4,338
all copper 'crush' washers need to be replaced every time. that said, in a pinch you can heat them red hot with a torch and the washer will be reusable. they are cheap. i carry spares.
on my old perkins, if it ain't leaking oil, i know one thing for sure. it's out of oil. :yikes:
english engines. well at least mine doesn't have a lucas fuel pump
Likes: rgranger
Jan 5, 2017
2,485
My Perkins has a CAV injector pump. I wouldn’t play with it unless absolutely necessary. The last time I had one rebuilt it was more than three boat bucks (cdn$)
May 25, 2012
4,338
2 years ago i had the injector pump rebuilt, last year was the injectors and starter. i run schedules, rebuilding gear that has time on it but ain' t broke is better/cheaper, "preventive maintenance."
the boys in green bay have all my rebuild records back to 81'.
..... but you still never know when she'll blow :yikes:
Oct 2, 2008
3,811
Pearson/ 530 Strafford, NH
Here we go, my money is riding on the high stakes game of boat repair. Did Sue approve of this and/or did U-tube come out with a new DIY.
dhjay
Jan 8, 2021
7
Hunter 31 Saylorville Lake
You may well damage the shims while removing the injector pump. Just measure their thickness and purchase new ones and replace with like thicknesses. They come in a set and are not expensive.
Likes: Scott T-Bird
Oct 26, 2008
6,432
I did get the gear case off on Sunday but couldn't get the injection pump more than loosened. I wanted to at least take a good look at it, but I didn't necessarily want to do any part replacement or rebuild. I brought the gear case home with me and was frustrated after an hour not finding a way to detach the pump completely. I called a mechanic yesterday and asked for help. They were stumped because it sounded like I was going about it the right way. After hanging up, I adjusted the fuel rack just slightly and off it popped! No problem ... just slipped right off the studs nice and easy. I guess I was overly concerned about the fuel rack position and wasn't doing enough to adjust it to exactly the right position to free it up.
Actually, I thought the gasket on the case was going to show an obvious defect, but it didn't really look bad. I peeled off a bit at the top of the case. The mechanic said that it was more likely that the crank shaft seal was leaking a bit. Well, I'm replacing the gasket and the seals so it would be a moot issue at this point. I was concerned about damaging the shims, but I was told that it is best to simply replace them - just be sure I'm replacing in kind. They were a bit crumpled and the mating surfaces with the pump need to be cleaned anyway. It should be relatively easy to put all this back together. A lot of cleaning is needed and I'm simply replacing a few of the parts that have some corrosion.
Likes: jon hansen
