Rope for lazy jacks - H310
Jul 2, 2019
102
Hunter 310 Pine Beach, NJ
Any rec's on this? The 310 uses the lazy jacks as a topping lift so stiffness is important, stiffness to weight is not. In fact I would expect heavy rope would misbehave less when wind is trying to sabotage my efforts to raise the main while the jacks are just dying to mix it up with the battens.
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
I had lazy jacks on my Hunter 31. Worked well, albeit occasionaly the battens got hung up on them. If I might ask what specifically are you asking about........rope diameter, lazy jack set up, etc? In the meantime you might find this article and thread post #2 about a Hunter 310 lazy jacks helpful.
Jul 7, 2004
8,542
Hunter 30T Cheney, KS
I wouldn't think it's a good idea to use lazy jacks as a topping lift. For example, lazy jacks should be eased up before you raise your mainsail so they don't get fouled in your battens. Your boom will drop.
IMHO, you'd be better off with light lazyjack lines and a real topping lift, rigid vang or boom kicker.
Likes: sail sfbay
Jul 2, 2019
102
My question is solely about what type of rope to use for a lazy Jack that is also used as a topping lift. The choice of using lazy jacks for double duty is not mine. It is hunters experimental design initiated with the H3 10. The boat did not have a topping left when it was built. There in 10 was to use lazy Jack’s to support the bone. I am simply asking for a rope recommendation
Jul 7, 2004
8,542
I get that. So since your lazy jacks have to be tight to support the boom, how do you raise your main without the battens getting fouled up in the lazy jacks? There's a fundemental flaw in that design.
4,638
My question is solely about what type of rope to use for a lazy Jack that is also used as a topping lift....................
I would use a low stretch, light weight rope like Samson XLS Extra T. That is what I use for my topping lift and outhaul.
Tim22
Jun 16, 2014
257
Hunter 310 Ottawa
The Hunter 310 came with lazy jacks that also worked as a topping lift. On my 310 (when new to me) they were fixed length vinyl covered wire similar to life lines but lighter weight. When I added a Stack Pack I removed the lazy jacks and installed a rigid boom vang to take the weight. This has worked well for the past 5 years.
Tim
Likes: Justin_NSA
Jul 2, 2019
102
Never liked the idea of using the LJs for a lift but that's what I was dealt. I have exactly one other H310 locally so I asked him and he said his boat had a topping lift. I then saw on the eng'g dwgs. that they used a lift on the furled mast option. OK Makes sense. No jacks here. Went to his house and he had a lift even though it was not a furled mast model. He said the mainsail does tickle the lift a little bit as the sail has quite a bulge in it, but it it never a problem. I will rig a topping lift. I am ordering rope now and will use Novabraid XLE performer, same as all other running rigging. Thanks for all replies. Much appreciated. Happy sailing.
Likes: Justin_NSA
