I know this subject has been discussed at length before but I would like to bring it up once more for some specific recommendations
My Hunter 41DS has a Xantrex Freedom 20 charger/ inverter(2000 Watt) which has started to occasionally overheat and trip the shore power offline. I have tested the fan which works when 12v applied but I don’t think it runs when the system gets hot. It is 15 years old so I would like to replace it. The current unit has separate channels for the house and start batteries
No simple plug and play replacement as this unit is no longer available. I have read many favorable comments about Magnum charger/inverters and they make specific models to replace this unit.
They are available as modified or true sine wave and 2000 or 2800 watt capacity. Unfortunately none of the current systems I have looked at have the internal start battery function so a combiner will be needed.
My questions are:
Would the Magnum be a good replacement? Other recommendations? An advantage of this system is that the original wiring for the remote panel can be used for the replacement- less wire fishing
Should I buy the true sine system?( almost double the price-The old modified system has been adequate for our needs so far).
The Magnum physical dimensions for the 2000 or 2800 watt units are the same (almost the same as the Xantrex). Is there any reason not to go with the higher capacity? Space is limited so a separate charger and inverter is probably not an option
If there are owners of the 41DS who have made this replacement, I would greatly appreciate your thoughts! I would like to keep the installation as simple as possible.
Apologies for the lengthy post and thanks in advance for any inputs.
My questions are:
