This is a follow up to answers I have received from a previous posst, follow ups from Raymarine and more researching and downloading of manuals, pictures, Youtube videos and more!
I have purchased Axiom 9 (E70366) and upgraded to i60 Wind Package (E70061 & E22078)
The Axiom did not come with sonar and I must use an external sonar module. (I have been told that the CP200 – E70366 is compatible with the Axiom 9 – E70366)
Boat currently has legacy Autohelm ST50 Depth and Speed control heads with transducers (Z091 & Z092)
Boat currently has SPX-10 Autopilot (E12198) with Fluxgate Compass (M81190) and Autohelm Rudder Sensor (similar to current Raymarine model). SPX-10 is connected to P70 AP Control Head (E22166)
I have enclosed diagram that I have updated after input from everyone.
Can I do the following:
Connect the legacy TXD’s for depth and speed AND new i60 Wind TXD from the iTC-5 (E70010) to the CP200 Sonar Module (E70266) and then connect them to Seatalkng 5 way (A06064)
or
Replace legacy transducers with new DST800 (A22154)
Is the DST800 compatible with the CP200?
If so, can I connect it to the iTC-5? And then to the CP200?
Can I connect the ST50 control heads through the D244 junction box to the Seatalk to Seatalkng Converter (E22158)
By doing so, will they receive the correct information from either the legacy TXD’s that are run through the iTC-5 and/or the CP200?
Will this information still also go to the Axiom 9?
The SPX-10 accepts the Autohelm Rudder Sensor and the Fluxgate Compass DIRECTLY into the CPU
It also provides for the option to be powered but I will set it up so that it does not power the Seatalk Network.
The Seatalk Network will be powered by the Axiom 9 cable that connects to the Seatalk Network
The SPX-10 is then connected to the Seatalkng 5 Way?
The wrench now is that the Axiom 9 I have doesn't allow for sonar without the external sonar module.
Is my diagram accurate?
Thanks for any help.
Chris
or
Chris
