Yanmar Starting Problems
Here's an update.
It appears there are 2 culprits in this problem. The solenoid circuit starts at the connection between the battery and starter where the battery cable connects. There is a smaller gauge (12?) red wire that runs to the key switch. When the key is turned on, it connects this wire to to the start button. The white wire then runs back to the solenoid. The solenoid is case grounded so there is only 1 wire to it.
The PO seemed to have a fetish with black electrical tape and silicone caulk. Tracing the wiring, I ran into copious amounts of black tape hiding who knows what. Both the red and white wires were covered in tape.
Replacing the white wire was going to be more challenging than replacing the red wire, so I opted to replace the red wire first. Rather than replicating the long run from starter to key switch, the run was shortened by connecting it to the positive bus bar with 10 ga wire. This shortened the run from about 12 feet to 18 inches and provided an opportunity to add a 30 amp fuse. And Success!
Started the engine a half dozen times, each time it roared to life, no clicking, hoping, and praying. On my boat, accessing the start button is difficult without removing the panel. Replacing the white wire is now on the To do list however, so long as the engine keeps starting on the first try, it will be moving down the list.
Thanks to all who offered suggestions and insight.
Likes: Ron20324
Beneteau 323 Annapolis MD
Thanks for the update, Dave. Good detail! This is the kind of a write-up I wish everyone would come back and do when they solve their problems.
Thanks Ron. I always like knowing how and why things work. Makes it easier to fix once I break it. :banghead:
Jan 10, 2012
8
Hunter 326 Ras Al Khaimah
And this thread lives on! My 2gm20f has had the dreaded clicking all last season usually starting on the 4th or 5th press until last time when it simply refused. Just spent the afternoon fitting a relay in the start circuit to circumvent the high resistance of the wires to and from the starter button and now it works first press every press!
Thank you everyone for this really useful information
Does anybody know what the solenoid that is located under Nav desk on a 375 does
You might have more luck starting a new thread, since this one isn’t too specific to your problem.
The solenoid might be related to nav equipment like the autopilot or NMEA bus. On the 37 there are relays for those things in the aft cabin and the switch on the main panel just activates the relays.
