On my Yanmar 3GM30F I am removing the pulleys and shaft couplers to gain access & remove the timing case and install a new gasket. I've removed my alternator. I've removed the pulley from the fresh water pump. Are there separate tools to remove the shaft pulley and couplers? This may be an obvious question for mechanics. My time is short for studying these issues when on the boat so I need to prepare in advance! Catalina Direct sells a coupler puller assembly, but I've seen other configurations for pulling the pulley off the shaft.
I'm try to figure out what tools I need to get the timing case off.
I've got all the hoses off for replacement so far
