Depends on the Delrin some is UV stable.I believe Delrin will deteriorate with UV exposure.
OK. It looks like he’s used the UV stable type, which is black. My (limited) use of Delrin has been with the original (white 550) type, which does slowly deteriorate, and crack. I see it has been discontinued & replaced with 511P. Good to know about the stabilized versionDepends on the Delrin some is UV stable.
Delrin® 527 UV Stable Acetal | Boedeker
Delrin® 527 UV Stable Acetal Properties, Sheet, Rod, Cut To Size, Parts, Tech. Support, Get A Quotewww.boedeker.com
Just out of curiosity, what was happening with the original aluminum sheaves that you felt the need to switch them to the acetal copolymer sleeves?One of my little projects for the winter was to make new sheaves for my masthead which I hope will be a little friendlier to my dyneema halyard than the original aluminum sheaves. I cut blanks out of a sheet of delrin with a hole saw, then shaped them in my drill press with a round file.
View attachment 189458 View attachment 189459
They were working fine. The halyard rides a little high in them, but it never caused any real problems. I just can't leave well enough alone.Just out of curiosity, what was happening with the original aluminum sheaves that you felt the need to switch them to the acetal copolymer sleeves?
Good to know.They were working fine. The halyard rides a little high in them, but it never caused any real problems. I just can't leave well enough alone.
Reading the detail on the Delrin website, notable is the nature in how the product is made. It could be a factor for the raw product you buy and then fashion into your end product.i just ordered round stock delrin to turn sheaves out on my buddy's lathe. I never thought about cutting discs with a hole saw. genius idea man!
that is a goos point. I will read up on that! Thank you for bringing it to my attention.Reading the detail on the Delrin website, notable is the nature in how the product is made. It could be a factor for the raw product you buy and then fashion into your end product.
