Just finished up my water heater bypass project. Up to now, every Fall I manually disconnected the in/out lines and connected them together. Now I just flick a couple valves and I'm done. (De)commisioning the heater is eazy peazy now. The PEX isn't as "bendy" as the old PB plumbing so I had to add some fittings.
My next plumbing job is to clean out the freshwater tank with a new inspection plate and insert my 10" carbon filter into the supply line right after the water pressure pump. Pics to follow
