Is Catalina 309 hull cored?
Apr 13, 2015
157
Catalina 309 Port Charlotte
Is there a foam or balsa core in the (below waterline) hull of the Catalina 309 - anyone know? I wan't to install a second depth transducer and am looking at the in-hull type to feed my Garmin chart-plotter. The in hull type won't work if the hull is cored. Also suggests not to install in fiberglass hulls thicker than 5/8 inch. anyone know the thickness (in general - I do realize it will vary in different locations on the hull).
had an in-hull in my last boat and that was great to not add another hole and it was more easily kept clean.
thanks for any insight...
Dave - in Charlotte Harbor
Catalina 320 Dana Point
To the best of my knowledge only the decks are cored on all Catalina, hulls are hand laid FG.
