So I went to check the boat this weekend I had not been out to check on it in 5 weeks and found that I had some diesel fuel maybe a 1/2 cup (maybe less) outside the tank in the drop in mold for the tank. (between the out side tank wall and fiber glass mold to hold fuel tank) I checked hoses and hose fittings but did not see any obvious point of leak. I do have a suspicion the seal for my fuel sensor pick is leaking a little (middle top). I filled the tank for winter and the boat is on the hard here in Canada Ontario and we have had some mild days high teens. Would fuel expansion explain the diesel outside the tank. Or would it be more likely that I have small leak in the plastic tank that I can not see. Any thoughts or experience would be appreciated, and if anyone has replaced there tank with a new one if they still have the information or contact info it might help if I need to replace the tank. Hopefully it is not the tank. Thanks everyone in advance to any help.
