My boat is now on the hard. This past Thursday and Friday I cleaned the topsides and hull, then waxed the hull. Some day next week back over and wax the topsides. On the hull, on the port side, there is a patch about 2' by 2' with an odd speckling. I believe it is simply oxidation, but it is odd being only in one place. Would you consider this mild or moderate oxidation? Should I use a strong compound on it, or go easier? Or is this something else?
There is a boat on stands next to mine and maybe one or two years older, but also gray hull. I don't think that hull has ever been thoroughly cleaned, nor waxed. The hull has all sorts of discoloration, speckles, etc. Are these issues worse on gray hulls?
