Old Nissan 2 stroke outboard parts?
Sep 27, 2008
181
Hunter 33 Danversport, MA
We have an older Nissan 3.5 HP (same as touhatsu, Mercury, Suzuki etc,..2 stroke outboard
This it the perfect lightweight motor but cant find ignition points for it???
anyone have a source??
Feb 10, 2004
4,231
Hunter 40.5 Warwick, RI
I believe that it has a solid state ignition. Hence there are no points. The spark is timed from the crankshaft magnet. The entire ignition system is the flywheel with embedded magnet and the solid state ignition module. And a shut-off switch.
Likes: SailingLoto
Aug 10, 2020
597
Catalina, Hunter C25 3559 Rocky Mount
yeah .. i agree. anything beyond about 1972 should be electronic ignition.
Sep 24, 2018
4,466
Catalina 30 MKIII Chicago
I believe, and someone correct me if I'm wrong, but the main reasons for solid state ignition on a boat would be...
-It's more reliable. Distributors are prone to problems in high humidity environments
-Much lower maintenance
-And most importantly, there's no distributor to make gas fumes go boom (although, there's no doubt it still can happen)
Sep 27, 2008
181
It has breaker points for sure, I have change them a few times over the years.
I would welcome a solid state update for sure
-na -NA Anywhere USA
You are correct that the small Nissan, Mercury engines were built by Tohatsu. Suzuki and Honda are different manufacturers. You may want to call the U. S. office of Tohatsu and ask that question. You will need the year, model and serial number. Former and retired Tohatsu dealer.
Sep 27, 2008
181
Got them from an OB repair shop in Hingham, MA They are obsolete.
but they have a substitute.
FYI... 3A Marine, Hingham, MA
