I noticed the other day that the sheave in one of my jib sheet blocks has a flat spot worn into it-
The block is 7 seasons old. Anyone seen anything like this or have any ideas on how to prevent it? Or is it just routine wear? I checked the one on the other side and it feels like it might have a bit of a flat but definitely not as severe as this one.
Incidentally, if you have blocks like this do check periodically that the set screw on the back of the base is still tight. On both of ours the screw has worked out over time. Once that happens the pin that holds the block to its base works out, letting the front of the block escape, and bending the flange on the back of the block. Here is what the whole base and block look like (with an improvised replacement set screw on the back) -
