Headliner (Ceiling) Replacement Project
Jan 25, 2007
366
Cal Cal 33-2 cape cod
Hi Folks,
Ripped out (Headliner) Ceiling (masonite covered with vinyl) not a bad combo, however, 30 years of wear/tear and occasional drip caused some swell & rot. So I painted some bead board and screwed it up, hopefully not literally. Here's some photos, it was a PITA, templates didn't fit, curves didn't match, found old leak-(needed to rebed clutch), plywood nailers had to be moved, some trim needed trimming, screw heads stripped....ect. Some cutting, sanding, swearing, and chiselling, and after almost every tool in the box was used, here's the almost finish product. I quit for key lime pie with daughter, will finish next week.
Cheers, Bill
291
Looks good! What type of beadboard did you use (vinyl, MDF, wood)? Did the old liner get torn up during removal resulting in the need to fabricate new templates?
Likes: william24424
Jan 25, 2007
366
Wood beadboard. Old headliner stayed in relatively good shape, some tears, but overall not bad.
DArcy
Feb 11, 2017
1,786
Islander Freeport 36 Ottawa
That looks really good. This is something I am contemplating, replacing the vinyl liner.
Jan 25, 2007
366
Best things about project, 1) Access to stuff underneath (check bolts, through deck stuff) 2) Easy to upgrade lights 3) Change color/upgrade look. The project took a couple of days, you'll need good templates, jig-saw, and patience. Very doable. My brother's quote "Caulking trim and paint can make a carpenter what he ain't." my thoughts are time & money can solve any boat project. Thanks for checking out my work.
.... My brother's quote "Caulking trim and paint can make a carpenter what he ain't."
hahaha
My father is a very accomplished (in my eyes) amature wood worker. His version of this same quote is.. "The difference between a good carpenter and a great carpenter is that a great carpenter knows how to hide his mistakes"
It is a sentiment that can be applied to many professions.
Sep 24, 2018
4,467
Catalina 30 MKIII Chicago
hahaha
Truer words have never been spoken
Oct 29, 2005
2,366
How do you secure the board & stuff to the ceiling? If you put a screw through won't that penetrate the coach roof causing leaks?
Ken Y
Likes: william24424
Apr 8, 2010
2,235
Slogan: Foredeck person - "Will Work for Key Lime Pie!"
The headliner upgrade did indeed come out great. Good work!!
Likes: william24424
Aug 2, 2005
1,155
Very nice looking headliner project.
Although you identified the material as wood, the finished work appears to look like a bead board material we purchased at Lowes for a home project. Please hold the boos and cat-calls! The material was solid white vinyl and was packaged about 8 (? ) strips in either 6 foot or 8 foot lengths. It was tongue and groove jointed, and it drilled, cut, and glued easily. We chose it for its white, yet paintable surface (the packaging said), and its ease of installation since the strips were about 12 inches wide. One side had a 2 strip look while the other side had a 3 stripe look.
Your finished overhead looks far superior to the two projects we completed. One was gluing up the carpet type of covering that was originally in a Precision and the other was a sheet vinyl replacement of the old carpet type headliner in an O'Day. The Precision project ended much better than the O'Day project
Likes: william24424
Jan 25, 2007
366
Wood Bead board (a plywood primed on one side from (Carby's lumber yard) was secured by small screws pre-drilled. Some went into fiberglass some to plywood nailers that were already glued/screwed to coach roof. The deck is sandwiched with balsa wood, (two layers of fiberglass, balsa in middle) won't leak because holes don't go all the way through deck. I didn't insulate since I'm coastal cruising/racing May-October. Also the screws and trim pieces make the sections easily removable.
DArcy
Feb 11, 2017
1,786
@william24424 I really like the look of that bead board. Replacing the vinyl headliner with bead board is now on the project list.
